May 23, 2017 at 12:05 pm
#131176
There’s probably a better way, but I use ROOM TOP, Predefined top, straight top. In attributes, change the “countertop height” (thickness) to the glass height you need, and change the texture to clear glass. Then on the floor plan, edit shape to make one dimension the length of your glass, and the other dimension to your glass thickness, then place it on your wall & adjust height. Voila, frameless glass.
