The manufacturer does not need to have 2 catalogues to do this. You simply use catalog manager to install the manufacturer catalogue, then go to “Rename short or long description of catalog”, select the catalog you want to rename from the drop down list, the under rename you can simply add the letter “A” beside the it…. sometimes you have to delete a portion of this to add a letter. Then you go back to catalogue manager and install the same catalogue again… it will allow you to install it a second time as the first one has been renamed. you can then label them both however you like.
Then when designing your kitchen you use one catalogue for the island and the other for the rest of the cabinets, and you can change the colors of each independently. hope this helps!
