August 2, 2017 at 5:04 pm
#141117
Hi Jim 🙂
If you’re using V11.8, you need to import it like you would other textures but before you do you need to make sure that the original image file isn’t too big. I generally open the image with “Paint” and re-size to around 70 pdi.
Change the glass texture of the window to your re-sized image using the largest measurement (height or width) of the window as the size.
That’s how I do it anyway. There may well be a better way but this is how it works for me.
Good luck
