Reply To: Disappearing, altered and skewed dimension lines
December 19, 2017 at 11:26 am #164437
Tiffany Gadway
Hi, Mike. thanks for tip…I have not tried a registry reset. Really, I’m not positive how to do that, but I suppose I will look into it when I have time…maybe after I fix all my files upon opening today. 🙂 We did a company wide upgrade about 2 weeks ago to 11-whatever the most recent version is, but this was an issue that existed before that and continues since, maybe even slightly worse than prior to the upgrade.
I am quite proficient with the Display Settings and wish it were more extensive, actually – I only use User Dimensions as I, too, find the auto option too broad and excessive when working on detail plans. My issue is specifically with user dimensions and have this issue regardless if a scheme is applied or not. I’ve tried both ways. I guess I will explore this registry reset you speak of….
thanks for the input, Mike
