Reply To: Custom Colours and Farrow & Ball
June 21, 2018 at 4:37 am #192430
Richard
Hi Yaprak.
It is an additional catalogue, so make sure you have it installed.
1. If you are using the simple ‘Colour change’ option, you need to select ‘Catalogue colours’ – ‘Farrow & Ball’
2. You can use it as a surface covering, Select a wall or object to surface cover in the normal way – ‘Farrow & Ball’ – Select the finish you want, and add a covering to modify in the usual way (As per tiling)
If you don’t see Farrow & Ball as one of your catalogue options, You may need to do the following in one of your designs:
‘Home’ tab – ‘Information’ – ‘New’ – ‘All’ – find the farrow & Ball cat and add it. If you don’t see the catalogue, contact 2020 to get it installed.
