Based on the fact that it only happens every now and then, I would guess its a system resource issue, maybe something running in the background somewhere. I would try closing everything, reboot, only open 2020 then try. If that doesn’t work try reinstalling your PDF printer, assuming thats where you are trying to print to.
I have had a lot of issues trying to print over the years and everytime I want to crush the computer into tiny pieces. Here are some other problems and solutions I have had:
-named elevations. If you rename you elevations and it has too many characters or special characters such as dashes or !# it causes errors
-file names with special characters, causes all sorts of weird problems they can’t explain.
-printer drivers and nvidia graphics drivers being too up to date. Have to roll back to older versions until 2020 catches up.
When all else fails call technical support (assuming you pay the maintenance fees)
