As an add on-
I’ve been doing my worktops this way for a while, if you use advanced graphics or another non tile catalogue when you hit the surface editor you don’t need to change the grout thickness to 0 as there is none.
If you want to position a vein exactly on the slab, you can select origin point and move it around to re position the texture.
Surface covering does not like cutouts! If you are going to use this around a sink, turn cuts through worktop and surface off. Then split your worktop into quadrangle blocks and apply each texture separately. The uv mapping gets messed up sometimes when you try to this method with cut through.
Equally though keep an eye out for new worktop catalogues in V6 as the textures are starting to come in full size 😀
