Thanks for the response . Doesn’t really help though . I don’t use the countertop wizard . Can’t stand it. Makes it harder to edit tops after theyret drawn and just takes longer. I prefer the countertop and trim dialogue but you can’t set the front overhang in preferences . You can only adjust the sides and back . The black countertop I’m referring too is the default texture when you do a render. It’s ugly and I’d like to change the default so I don’t have to do it with every new drawing I do. And yes, I can change the countertop to whatever thickness I want after I’ve drawn it, but it would sure be nice to set a default that I use most often.
2020 needs to catch up with some of the other software out there . I was using programs 15 years ago that we’re better than this .
