July 27, 2020 at 4:21 pm
#291201
Hi Alan
I had the same problem with the TKC files while back when having discussion with Fusion support team.
Any way You need to select a file or design which is VERO Rail well this is what they TKC call it. when ever you select larders it will ask for if you want to add the Rail you select it and it will add. And also the base unit need to select with rail already onit.
And Also main important If you selecting catalogue JIGSAW then it will work or Selecting Component it wont add unless you spend a lot of time adding your self.
TKC are more closer with articad so they support them more then us for some reason. BUT 2020 Fusion is one of the best in comparison.
