March 1, 2022 at 8:49 am
#360084
You can rotate the LED lights as items however I do not use this. I basically create a 15mm x 15mm x however long box, place it inside the cabinet and change the material by Control + U – Universal Lighting – Glow 1600mm. This will light the box itself and give a bit of lighting as well but won’t give you the same effect as you get from LEDs.
