Reply To: Countertop Inside Corner
March 25, 2022 at 7:40 pm #361741
Lara Fitzpatrick
Hello!
I just did a quick test and I think I have it sorted for you! I drew the countertop shape with the running line tool first and the made it 3d using countertops then square foot tops.  Once the shape was converted to a countertop (it should be red lined) I right clicked inside of the countertop and chose edit shape.  I then got super close with my pointer to the point I wanted to radius, right click again and the menu will pop up and pic radius corner (its a very similar process to an outside corner point) if you drag that inside corner point it will radius it for you and you can choose how many inches you want to radius it in the box where the placement tool is. Does that make any sense? Hope this does and good luck!
L
