June 30, 2022 at 3:30 pm #372349
Hi Kristin,
Generally when you are modifying a unit that comes with its own appliances, you would have to do this from the Attributes > Variables section of the item. Unfortunately I do not have the Cabico catalog to test so for this example I used the Sample_E catalog.
I used the tall unit SO3080. From within the Variables section, I went to Quantity and found the option for ‘Oven Style’. In this case, we would change the value from 1 to 0. Changing its value from 1 to 0 would remove the shape of the appliance from the tall unit. -See images.
Now that we’ve removed the appliance, we can go to the Dimensions section in Variables. In here we will have the ability to play with the config. height. (There can be more than one Config. height depending on how many doors/drawers there are). In the case of my unit, there are config. height 1 and 2 for the door and drawer. Config. height would be the bottom of the unit (base doors) and config. height 2 would be for the top (wall doors). We will also have the Oven width and Oven height which refers to the opening left for the appliance. Playing with these options will make the doors and opening either bigger or smaller. -See images.
