Hi Erik,
Are you using the note tab in attributes? This would be helpful when placing “note on exit” if the saved scheme settings applied to this tab, as well as shows up on the elevation.
I do have a work around though. If using the annotation note button, you can copy the note into the floor plan and drag and drop it up into elevation when the screens are split. You can also drag and drop other annotations like merged shapes/splines/ circle/ellipse. (It’s much easier to draw to scale in floor plan than in elevation.)
If you have your display schemes saved and applied to the tabs as default in preferences, you shouldn’t have to change the note each time.
Santiago! There are “Note Font Settings”, but I can’t for the life of me figure out where this feature applies- neither in design or layout tabs… So it’s somewhere, it just needs a little love 🙂
Kayla
