Reply To: Island overhang without knee wall?
January 9, 2023 at 6:41 pm #418487
Hi Rick,
Altering the overhang of regular countertops (countertop and trims) and countertop wizard countertops is slightly different.
When using the the counters from countertops and trim, you would use the method you mentioned above.
When using the Countertop Wizard, once it has been added, you can right click directly on the countertop line and then use ‘move and intersect’. (When you hover your mouse over a countertop line, it will highlight in green). -See images below
The ‘move and intersect’ option does not appear if the countertop you have has a cutline. In this case, you would use ‘Add Line’ and extend the overhang where it needs to be. Once that is done, right click the point and bring that to where it needs to be. (You can go to Annotations and use the Line tool to add lines so you know where you need to place the point to get a straight countertop).
Hope this helps out a bit!
