Reply To: CABINETS UNDER STAIR – ANGLED CEILING?
May 24, 2023 at 11:23 am #423904
Hi Christine,
You can create this type of angle using the custom shapes from the ROOM catalog. In the Local Browser, select ROOM > Architectural Elements > Custom Shapes > Wall Custom Shapes … then you can use the TRIANGLE-R.H or TRIANGLE-L.H. You can modify the triangle to be the size you need from within Attributes.
