August 7, 2023 at 5:31 pm #429139
Hi James,
You can add a fireplace to your drawing by finding it within the Cloud Browser. You can ‘Select All’ catalogs in the first menu and then use the ‘Contains’ bar to search for Fireplace. You would only be able to add a mantel from the cloud if it exists as a created object. I was unable to find one from any manufacturers so I created my own using a 3D Shape. I have attached an example of what I created below.
HERE is an article which will show you how to create a 3d shape from the ‘Draw’ tools we have in the Annotations tab. In the video, he will demonstrate how to create a countertop (which is more or less the same). When you right click on the shape you created and click on ‘Make 3D’, select ‘3D.SHAPE’. Once you have your 3d shape created, you can right click on it to go to Attributes > Variables. From Variables, you will be able to change the texture to anything you wish.
You can even import your own textures to the program if you would like to use a custom colour/wood. HERE is an article which can help with that.
Hope this helps!
Kris,
