Right-click on your toekick, go to Edit Shape. Right click on the end point which shows as a square. It will show the word ‘Point’ with an arrow, hover over this to get the drop-down menu. Click on Add point, drag your mouse to the next corner or end point and left click on it to set it there. You can then right click on the new point and do the same process again and again until you have all your moldings placed. Remember to drag your mouse in the direction you want your molding to go so your molding line follows your mouse. Then in the upper left of the 2020 screen you will click on Accept changes. This will set everything in place. You can use the same first couple steps to then go back into those molding lines and delete sections if you need to.
Reply To: Toe Kick
