September 23, 2015 at 2:52 pm
#51149
Hi Jordyn,
please try this other method.
Save the Sketchup shape/item to your computer first
Then complete the following steps to import a Sketchup shape:
In the File tab, click Import and then choose From local storage.
In the Import dialog box, select the file .skp type, the file name and then click Open.
The 2020 Units dialog box displays the imported image dimensions and allows you to import using different types of measurements.
Click Continue.
Click in the 2020 Floor Plan to add the item.
Move the item to the new location and click to set the item.
If this doesn’t work please contact our support team at support@2020spaces.com
Please describe your issue and someone will be contacting you on this subject.
