Hi Denneen,
you may want to try the “editable floor tiles” found in the room catalog, they are pretty versatile and may give the effect your looking for with a lot less work.
If you want to use the custom texture wizard, the following should help:
– Your image file should be a perfect square that is tillable either (128 x 128), (256 x 256) or (512 x 512).
– The size should be one number the inches of the tile in your case, if the tile is 10 x 10 then you would enter 10.
– A 10 x 14 tile is harder to do because you would need to tile your image in paint or photo shop to make it a perfect square, something like 7 tiles across (10 inches x 7 = 70 inches) then 5 tiles down (14 inches x 5 = 70). This will give you a perfect square which you may then tile seamlessly (I didn’t include the grout).
Hope that helps. For more info you can click on the Help tab in 2020 Design and search for custom texture in the content.
Dominic
2020 Tech Support
