It would be GREAT!!! if we had more CAD functions as to make the paper space look more Professional. Having the option to show door swings on doors as well as cabinets with dotted lines that you can change the color on would be fine. Having “CL” icon for center line not be so touchy and actually stay where you want to put it would be nice. The wall ID on the floor plan shows through on the renders as well. I would also like it you could print the whole paper space as one file and not have to print each file to PDF then put into one PDF. If there is a way to do this , Please let me know. I would also love to see a “lock walls” option so if you move one wall it doesn’t move all the walls. I know you can go into an individual wall and modify wall but it sometimes still doesn’t do it. If you could also make it so when you make a “Poly line ” into a 3D object like a beam you could edit in an elevation view allowing the beam to follow the vault you created. These are just a few things that would help. Love the program besides the constant freezing….
Reply To: WishList
