Reply To: Where do you go to change the text in the title block on your printed drawings
July 18, 2016 at 5:22 pm #95833
@ Christina – Give the support line a call at 1-866-697-2020 and ask them for the Title Block Editor.  It’s a little utility that will allow you to change your logo and the text in the title block for the regular prints and the drawing layout.  They will be able to give it to you via a team viewer session.
@ Ravi – Do you mean different pages of the same layout or completely different designs?  You should be able to print the tabs of 1 layout to pdf.  If it is from different design files you will have to print them individually and maybe your PDF creator will let you merge the different files.
