January 2, 2019 at 1:19 pm #222101
Anvar Bakhtiyarov
ParticipantI’ve been using panels a lot on previous versions for multiple occasions such as placing tricky toe kicks, some side panels etc. Now I can’t find it anywhere in the Cloud or in preinstalled catalogs.
Where did they go?
January 7, 2019 at 1:24 pm #222745
Santiago Morales2020 ExpertHello Anvar,
Can you please provide more details on the panels you are referring to? From which catalog were you taking them?
Catalogs could have their assorted selection of panels. Perhaps the ones use were using came from the manufacturer catalog you were using? I am not sure.
Santiago
January 10, 2019 at 1:36 pm #223293
Ariana ThompsonParticipantI use the generic CUBE shape for that sort of thing – just give it the dims of the panel you want!
It in the View Ribbon in the Catalog Browser. “ROOM 1 – Sample – Generic” under Architectural Elements.
I use it so much I put it in my Idea Centre.
January 16, 2019 at 12:32 pm #224095
Anvar Bakhtiyarov
ParticipantI’ve been using cube for that kind of purposes. However, I found more elegant way I suppose.
You draw a rectainge and then choose “Make 3D”. Here you can not just make it 3d shaped but also turn it into countertop, splash etc.
January 16, 2019 at 1:37 pm #224096
Ariana ThompsonParticipantYes, Anvar I have also used the “Make 3D” function as well – I largely stopped using it for other than countertops – as many of our installers want a printout from the Countertop Tab – and the Make 3D function shows up in that tab – and I only wanted the actual countertops to be seen in that tab – though its still the best way to make curved walls etc!
