2020 Insight Daily Tip: imos connection situations
  • October 2, 2015 at 4:10 pm #52005
    Aaron Milley
    It is possible to enable and disable imos connection situations (CS) through the Article designer using a variable.  To access this functionality you must first edit the article, on the element go to the connection tab and right click the ‘To’ part where the CS is selected and select ‘Detachable through variable’.  The result must = 0 or 1.
  • November 28, 2016 at 4:13 pm #112864
    Priscila
    Hi AAron.
    About IMOS 9.
    <p class=”MsoNormal”>We have insight 4.5.8 working with imos version 9.</p>
    <p class=”MsoNormal”>Currently our Imos V. 9 is running on Windows XP.</p>
    <p class=”MsoNormal”> This imos 9  can work in S.O windows 7? .</p>
    <p class=”MsoNormal”>Thanks.</p>
