Lighting Wizard button not appearing after Sensio catalog install v11.3
    • November 23, 2015 at 2:38 pm #62248
      Jon Peterson
      After installing the sensio lighting catalog on V11.3, the lighting wizard button does not appear. Is there something I am missing?
      Thanks,
      Jon
    • November 23, 2015 at 2:43 pm #62249
      Hi Jon,
      Just reinstall the catalog and the button will come back.
    • November 24, 2015 at 7:10 pm #62352
      Jon Peterson
      I installed 11.3 (full download) on a new machine. Then installed the Sensio Lighting catalog and the button never showed up. Is there a special procedure to installing the catalog? I thought since it was an executable file it was a click-n-run install.
    • November 25, 2015 at 11:23 am #62636
      I had the same issue with 11.3 and they said this is a known issue. I loaded up the Sensio Catalog and it didn’t work. I also didn’t have the countertops working right either. Has anyone heard of when the fix will be out? Technical support had no idea on Monday when I called.
