“Mover Tool” in Scaled Print Preview
    • August 12, 2021 at 2:43 pm #342161
      Jeremy Pyatt
      Hello!
      In previous versions of 2020 you could do a print preview in scale, then choose a mover tool that you could drag the layout around to get the part you want in scale on the page.
      So if I preview in 1/2″ scale, and the whole design doesn’t fit on the page, I could drag it so the section I wanted is in the print range of the page.
      How do I do this in the current version?
    • August 12, 2021 at 2:54 pm #342174
      Hey Jeremy,
      To move the drawing on your print preview, there are two methods.
      (Do both IN the print preview)
      First one is to click and hold down on the scroller on your mouse. When you do this, you will see the mouse turn into a fist. When you see the fist, you can move the design around.
      Second is to click and hold down on both left and right clickers on your mouse. Again here your mouse will turn into a fist, which means you can move your drawing on the print preview.
      Regards!
