Print to PDF – Selection
    • May 1, 2020 at 10:41 pm #279929
      Carla Anderson
      Now that I have upgraded to use the Pilot program, I am no longer able to use the Print Preview to create a PDF or even print a specific selection, eg. Countertops or Cabinets only. This is now grayed out. They options are not available.
      I use this all of the time. Help!
      You must be logged in to view attached files.
    • May 4, 2020 at 11:25 am #280020
      Hi Carla,
      I’ve installed the pilot as well but I havent experienced an issue such as this. I would suggest to run basic maintenance on the program to clear out the registries and recreate them. This will remove any preferences you may have set up for yourself and revert the program to the default settings. Here is an article to help you run the basic maintenance.
      After running the maintenance, you can open the program to test it out. If there are any issues along the way, feel free to call into support for any assistance. The support number is 1.866.697.2020.
