Rev-A Shelf Attaching Issue, Up/Down
    • October 12, 2019 at 10:04 am #253177
      David Bauer
      When placing a Rev-A-Shelf pullout into a tall pantry program it would not respond to the elevation corrections correctly .  When first placed the pullout was approximately 4 inches too low, i.e. in the baseboard.  When I tried to correct it with the up/down command It went in the opposite direction and then when I tried to re-corrected with a negative elevation it went in the same direction three times farther than the amount entered.  Each time a correction was made it reversed direction and needed a larger and larger number to move a fractional amount.
      To correct for the presentation:
      I opened the cabinet so I could see the pullout, rendered and used the up/down in rendering to adjust the elevation.
    • October 15, 2019 at 9:56 am #253622
      Hi David,
      Would it be possible to get the specific add-on and the specific tall pantry so that we can test the issue in house?
      Thank you
    • October 21, 2019 at 6:56 pm #254349
      David Bauer
      Neil,
      Sorry I replied to the NoReply and did not realize it,  here is the file try to move the pullout up and down.
    • October 22, 2019 at 10:07 am #254418
      Hi David,
      I’m not seeing the attachment for some reason.  If you would be so kind as to email it to residentialsupport@2020spaces.com to my attention it would be greatly appreciated.
      Thank you
