Any way to uncouple Cloud Browser from Local Browser?
    • November 4, 2021 at 11:47 am #350269
      Hi gang!
      In V12, is there any way to have the Local Browser on one side and the Cloud Browser on the other side of the work area, like in V11? Having them both on the same side and having to toggle back and forth is really annoying.
      Cheers!
    • November 4, 2021 at 11:53 am #350270
      Santiago Morales
      Hello Ariana,
      Yes you can. You will need to drag the Cloud Browser tab to the desired location. You can then save your layout under the Custom Screen Preset (on the View tab).
      Santiago
    • November 4, 2021 at 12:01 pm #350271
      Ah! Got it!
      Thank you!
    • November 4, 2021 at 1:52 pm #350289
      Robin Hernon
      You can also select view in the ribbon, and then under screen preset, select Classic. That will put your cloud browser/cloud configurator on the right hand side and the info/placement/and local browser on the left hand side.
    • November 4, 2021 at 1:55 pm #350290
      Oh, thanks Robin!
      We may do that in future – as that is how our current V11 is. Though right now I’m trying to configure V12 *differently* (also using a different colour scheme) than our V11 so we’re instantly aware of which one is open (since the desktop icons are the same).
      Once we switch completely – we may follow your advice and change it back to how we’re used to it.
      cheers!
