June 14, 2017 at 4:44 pm #134989
Chris Blackman
ParticipantThanks in advance!!!!
Anyone have any tips for creating a Domed Ceiling or a Cathedral ceiling?
For the domed ceiling I have tried the Underground catalog’s Barrel Vaulted ceiling and that works alright for a rounded ceiling but my salesman would like a circular dome in the middle of a room and I just can’t figure that one out.
I have done cathedral ceilings before, but it becomes a problem when I have 2 rooms sharing a wall and only 1 side is a cathedral. Without creating a 2nd wall for the non-cathedral room I get all sorts of craziness with the ceiling.
Creating a 2nd wall leads to it’s own set of problems with measurements and corners, so I like to avoid that if I can.
June 15, 2017 at 9:16 am #135030
Kevin Roberts – CatalogPros.comPilot ProChris – Since you have the Underground catalog, try using BOWL.02. Make it 144″w and 24″h (or as needed). Then click on Variables, Angle, and set Angle Z to 180. There’s an example HERE.
Another quick way to draw cathedral ceilings is to keep your walls high (or set your ceiling texture as transparent) and use TRIANGLE-R.F resized as needed and floated into place.
June 15, 2017 at 10:11 am #135035
Chris Blackman
ParticipantKevin,
Thanks! I will try that for the dome ceiling. I have only been working with 2020 for about 12 weeks and I haven’t really had the time to delve deeply.
I’m going to take some time and look more at your website as well.
Chris
April 10, 2018 at 10:09 am #181518
Travis Ferrell
ParticipantWhere’s this underground catalogue? The newest versions of 2020 do not have decorative items list anymore and I cannot create vaulted ceilings without the wall/ceiling options. I can only find wall options. Does the underground catalogue create this?
