February 12, 2020 at 2:54 pm #267072
Jenifer Daniel
ParticipantI’m drawing a reception desk which will sit atop an 8″ raised platform. I used the floor obstruction element to create my raised platform in VI. I’m able to change the Z height on all of my components, connectors, etc. in my AutoCad drawing using the Change 3D height tool, however it will not change the 3D height of my panel configurations. What gives?
February 13, 2020 at 8:47 am #267129
Aaron Hall
ParticipantHello Jenifer,
I did some testing with the Change 3D Height command and there does seem to be an issue when used on a Panel Builder object. I did find a work around for this issue. If I convert the panel to 3D in the drawing and use the Change 3D Height command on the 3D version of the panel it elevates correctly and has the correct elevation in Visual Impression.
I’ve notified our QA team about this issue so they may review it and get it corrected. Thank you.
Thank you for bringing this to our attention.
February 13, 2020 at 8:59 am #267130
Jenifer Daniel
ParticipantI did try this, and while the panel config did elevate to the correct height in my AutoCad drawing, it reverted back to “0” height in Visual Impression. If it matters, I’m using Allsteel Stride.
I ended up having to explode the panel configs, and change the 3D height on all the frames & tiles individually.
June 7, 2024 at 3:24 am #438702
ivy michael
ParticipantAdjusting Z height on panel configurations is vital for optimal performance and precision in CNC machining. As an expert in manufacturing, I emphasize the importance used trimble tsc7 of fine-tuning this setting to accommodate different materials and tooling depths. Proper Z height ensures consistent cuts and enhances overall productivity in machining operations.
