How can you tell that an exchange service is not a scam?
    • January 21, 2026 at 3:55 am #441708
      Noble Green
      I’ve been dealing with crypto for a few years now, mostly holding, but recently I started exchanging more often. That’s when I realized how easy it is to make a rushed decision and end up with a worse rate or unexpected fees. A couple of weeks ago I swapped USDT late at night and only later noticed I could’ve done better if I had compared options properly. Since then, I’ve been trying to be more systematic instead of acting on impulse. Curious how others approach exchanges — do you have a routine or just decide on the spot?
    • January 21, 2026 at 4:25 am #441709
      Bart Lee
      I had the same issue before and eventually understood that my main problem was lack of overview. Now, before exchanging anything, I usually check Obmify . I don’t use it to exchange directly, but more as a way to see what services are available at the moment and how rates compare. Before that, I was opening multiple tabs, checking random platforms, and still feeling unsure. Having everything laid out in one place helped me slow down, avoid bad deals, and feel more confident about my choices, especially when the amount isn’t small.
      • This reply was modified 2 days, 20 hours ago by Bart Lee.
    • January 21, 2026 at 5:07 am #441713
      Alex Kools
      This topic is very relatable. I don’t trade daily, but every time I exchange crypto, I double-check everything because one small mistake can be annoying later. Reading how others build their own process is useful — it shows that being careful isn’t about being slow, but about being intentional. Crypto already has enough uncertainty, so clarity really matters.
