December 14, 2022 at 9:18 am #417646
darren mckeownParticipantHi i was wondering how to speed up the videos in fusion. or can the speed be set by choosing frames per sec?
December 20, 2022 at 8:21 am #417868
Larry Tamang
2020 ModeratorHi Darren,
The amount of time Fusion takes to generate a Movie depends on the what Movie Generation Settings has been selected.
For instance, Movie generated in render settings Colour Fill will be quicker to complete in comparison to Presentation Plus Render.
Higher Bit Rate would mean better video quality but will take longer to complete.
Higher Frames Per Second would mean, a smoother video quality but will again take longer to complete.
Larry Tamang
Fusion Support
March 27, 2024 at 12:20 am #437762
Shane Pamela
ParticipantIn Fusion, you can adjust the speed of your videos using the TimeSpeed node. First, add a TimeSpeed node to your Fusion composition from the toolbar under the Time category. Connect the TimeSpeed node to your video clip by dragging the output of your video clip node (like Loader or MediaIn) into the input of the TimeSpeed node. With the TimeSpeed node selected, you can adjust the speed of your video using the Speed parameter in the Controls panel. Decreasing the Speed value will slow down the video, while increasing it will speed it up. You can also enter precise values to set the desired speed. Preview the video to see the changes, and once you’re satisfied with the speed, you can render the composition to save the modified video. Regarding setting the speed by choosing frames per second (fps), Fusion primarily operates on a frame-based timeline, where the speed of the video is determined by the frame rate set for the project. You can change the frame rate of your composition by going to the Project Settings (Ctrl+Shift+;), where you can adjust the frames per second (fps) value. However, changing the frame rate affects the duration of the video rather than its speed. To specifically adjust the speed of the video, you’ll need to use the TimeSpeed node as described above. Remember to experiment with different speed values to achieve the desired effect, and don’t forget to save your work regularly. Happy editing!
August 29, 2024 at 9:16 pm #439578
Dan RSprinkle
ParticipantHello! This is a really interesting article. Discussing Parent’s movie configuration is extremely insightful for families who want to manage their movie watching experience. Covers many different aspects, such as age-appropriate content, educational value, and how to make movie nights fun for all ages. Overall, I think this forum is a great platform for parents to exchange ideas geometry dash subzero and enhance their family movie watching traditions!
