October 10, 2017 at 2:56 pm #153091
EdithParticipantGreetings
2020 Design 11.8.1 is now available for download.
The version can be download here.
New features include:
- Ability to import more recent Sketchup Models (up to 2016 models)
- Drawing Layout can be printed in “Draft” or “High Quality” mode when a frame contains hidden lines or wireframe “Isometric” or “Saved View”
- The Closet Flex_C and Flex_CM catalogs have been augmented with the following:
- 37 additional Door Styles
- 10 additional Wood Finishes
- 30 additional Pull Styles
- Over 300 additional colors
October 11, 2017 at 12:54 pm #153332
Marty Keenan
ParticipantDo I install over V11.8.0.53 or do I uninstall that version and then install V11.8.1?
October 11, 2017 at 3:21 pm #153408
Neil WilsonParticipantHi Marty,
Best practice is to remove the old version before installing the new one. If you go in to the control panel and go to programs and features and select Design you will be able to select change. Once you do that click next, then select remove. At this point you will be given the choice of a Complete or Basic uninstall. A complete uninstall removes everything except your design files. A Basic uninstall will remove your software but leave your catalogs so that when you upgrade you won’t have to reinstall all your catalogs.
October 11, 2017 at 3:44 pm #153419
Marty Keenan
ParticipantThanks Neil!
Should I just do the basic uninstall?
October 11, 2017 at 3:48 pm #153429
Neil WilsonParticipantIf you have less than 5 manufacturer catalogs installed I would do a complete uninstall and then just reinstall the manufacturer’s catalog. If you have more than that then Basic will do the trick and save you the time required to reinstall a bunch of catalogs.
October 11, 2017 at 3:54 pm #153439
Marty Keenan
ParticipantThanks! I have more than 5 so I will do the basic.
October 11, 2017 at 8:43 pm #153525
Mike LangensiepenPilot ProJust FYI, I tried an install ‘over the top’ of an earlier V11.8 and it was actually worse than doing a Basic Uninstall as it lost all my preferences when it installed.
So definitely, Basic Uninstall then install the new version. Not all the preferences stay up (the Assistants all switch back on even if they were turned off before) but definitely the best option.
October 16, 2017 at 1:08 pm #153897
Steve CollinsParticipant🙁 Install crashes. Says there is an error, and it terminated.
Not liking the idea of wiping it out, and doing a new install yet AGAIN…
October 17, 2017 at 10:57 am #153936
EdithParticipantHi Steve
Could it be possible to send us an image of the error so we can understand better what may be causing the problem.
Please send it to this address: residentialsupport@2020spaces.com
Thank you
October 17, 2017 at 12:03 pm #153950
Steve CollinsParticipantHey Edith,
I must of had a corrupt download. I re d/l’d the file, and it was fine. 🙂 Thanks though. So far so good.
November 29, 2017 at 8:12 am #162174
samer hamdoni
ParticipantHi how can i download this version
November 29, 2017 at 8:25 am #162175
Chris Blackman
ParticipantI see a version 11.8.2 from 11/2/2017 – is that the one?
