Stacking Crown Moldings
    • February 10, 2022 at 10:31 pm #358779
      Melina Murphy
      Has anyone had success in stacking top moldings? It’s supposed to work by dragging and dropping on top of the first molding, but I’ve had zero success with V13 doing this.
      The only way I can stack is by using a running line, but it doesn’t always look great for some reason.
      Any tips are appreciated!
    • February 11, 2022 at 1:34 pm #358799
      Hi Melina,
      If the stack is not being added from within the floor plan, its possible you may need to first zoom into the item more and then try to add the stack. If this doesn’t do the trick, you can create an elevation of the wall and then create the stack there!
      Hope this helps!
