Applies to: 2020 Worksheet
Price adjustments that are added to a worksheet are not automatically reflected in a report design. Price adjustments need to be enabled in the report template if you would like them to show on the report.
- After you have generated your report, click the edit report design button or choose Edit Report Design from the Reports pull down menu.
- In the Report Designer program, go to the Edit menu and choose Section Properties…
- In the Section Properties window, select the item detail tab
- Put a check mark next to “Show Price Adjustments”
- Press OK and then save your report design.
You can now refresh your report view and see the price adjustments on the report
