May 1, 2017 at 3:07 am #128778
Mike LangensiepenPilot ProHas anybody had issues with the Countertop Wizard in 11.7?
I am unable to assign more than 1 edge
I am unable to alter the benchtop layout (add points etc) once the Countertop Wizard has finished.
I have also just tried to uninstall V11.7 to check V11.6.2 and the uninstall failed.
May 1, 2017 at 3:27 am #128779
Mike LangensiepenPilot ProEdit to the above
Not being able to add points was probably me but definitely unable to define more than 1 edge on my sample drawing. About to reinstall and try again.
Managed to uninstall V11.7 after a reboot
May 1, 2017 at 3:57 am #128780
Mike LangensiepenPilot ProAfter further checking, still unable to add edges on more than 1 section. e.g. In an L shaped kitchen, I can add a front and side edge to the vertical section but it won’t then let me add edges to the horizontal section.
Once the wizard has finished, I can then right click on the unedged section and add edges by running through the wizard again.
I AM able to add points and edit as normal
