March 1, 2022 at 8:16 am #360070
Dean GilgristParticipantHi folks,
I primarily install wardrobes and was wondering if there was anyway to use the universal lighting catalogue to lay LED strips vertically instead of horizontally. Tried everything and cant get it right.
Thanks in advance.
March 1, 2022 at 8:36 am #360073
Ryan Jackson
ModeratorHi Dean,
You should be able to do this. Please see the below article on item rotation which should help:
Knowledge: Understanding Item Rotation in 2020 Fusion (2020spaces.com)
If you need any help after going through this please either call on 01233 635 533 or email fusionsupport@2020spaces.com
Kind Regards
March 1, 2022 at 8:49 am #360084
yaprak yalcinkaya
ParticipantHi,
You can rotate the LED lights as items however I do not use this. I basically create a 15mm x 15mm x however long box, place it inside the cabinet and change the material by Control + U – Universal Lighting – Glow 1600mm. This will light the box itself and give a bit of lighting as well but won’t give you the same effect as you get from LEDs.
March 2, 2022 at 3:47 am #360272
Dean GilgristParticipantThanks Ryan and Yaprak.
For some reason they wouldn’t rotate effectively enough before, but now it seems to be working better :\
The box idea is really good as it stands out.
Thanks for the help.
