Reply To: Changing Surface dimensions
January 23, 2018 at 8:23 pm #166961
If you want to grab a particular part of an image then there is a free screen capture program called MWSNAP that allows you to specify the height and width of the capture area. You then just move the onscreen rectangle around to capture the section you want and save it back ready to use in 2020.
MWSNAP can be downloaded from the address below and is a small, fast and SAFE program.
https://www.mirekw.com/winfreeware/files/MWSnap300.exe
Because MWSNAP can respond to a key combination, it’s also useful for capturing an onscreen image that would otherwise disappear if you used (for example) the Snipping Tool.
