Reply To: 2020 worksheet cells are tiny and unable to expand
April 20, 2018 at 1:32 pm #182763
Eric DeVito
It appears you are using a very high resolution for your display with high display scaling. Please refer to this knowledge center article for solution.
The other message I suspect you have not set a proper location for your local projects.
Go to the Tools menu, and choose preferences. Then click Folders+Files. Set your local projects path to a valid location.
If you require further assistance, give the technical support team a call at 800-638-6002.
