Reply To: Print an entire library price sheet
February 11, 2019 at 10:26 am #226538
Chad Bulthuis
Thank you for taking part in our Community!
The command you’re remembering is CAPXTESTBLOCKS.  If you type that command in AutoCAD with 2020 Cap loaded, you’ll be prompted to choose a catalog and set spacing values.  Click on the “Test” button and all of the items with graphics will be placed in the drawing.  (Items without graphics will be noted as text within the drawing.)  Do a Worksheet take-off of that drawing and you’ll get a worksheet with all of those items.  You can update against the catalog and turn on the “Catalog Location” column and sort by that column (or any other column that works for you).
Remember that you’ll have every item that has a graphic, items that were noted as text in the drawing won’t be in the worksheet.
