Hi Laura,
The drag and drop list contains your catalogs. At the top select the catalog you want to use and then below in categories select the type of catalog. You click down through the menus until you get to the BOLD entries and then drag the bold entry you want to use onto the floor plan. If you know the nomenclature associated with cabinet you want (B30 for example) you just type that into the search bar at the very bottom of the drag and drop list and it will bring you directly to the entered cabinet.
The placement tool is great for moving stuff around on your design or putting in windows and doors. You can set how far from the left or right wall you want to place an item or you can shift items around in tight spaces by selecting how far to move them then clicking the arrow that points in the direction you want to move it.
If you go to File \ Help \ Watch Training Videos in the 2020 Design program there is a whole section of helpful videos about placing items.
