February 11, 2022 at 1:34 pm
#358799
Hi Melina,
If the stack is not being added from within the floor plan, its possible you may need to first zoom into the item more and then try to add the stack. If this doesn’t do the trick, you can create an elevation of the wall and then create the stack there!
Hope this helps!
