Reply To: ‘Save As Image’ Mishappenings
February 28, 2022 at 6:09 pm #359996
Hi Erik,
We are aware and have marked the surfacing issue down as a bug to later be fixed. As a suggestion, rather than using the surface tool to set a flooring material, you can set the material from within the rendering. HERE is an article that explains how to change the default flooring texture for the program and for individual designs.
We are also aware of the ‘selection’ issue regarding lines and dimensions. At the moment the only work around for this would be to right click to select the line or dimension.
As for the issue with the Legend and the issue with the surface cutting into molding, would you be able to send us a copy of the design in question so we can take a look and see what’s going on? You can send it to residentialsupport@2020spaces.com with some information.
