May 20, 2022 at 2:55 pm
#367562
Hi Jason,
To remove the names of the cabinets easily, you can right click on an empty portion of the floor plan and go to Display Settings. From there, you want to select Residential and then you want to uncheck Display under label. Once that is done, you can click on Apply and OK. -See image below. Keep in mind, these would be the same steps for your elevation area.
