October 11, 2022 at 11:22 am
#376195
Hi Brenda,
If your cabinet is inside of your wall, you can right-click the cabinet and use in/out to take it out of the wall. One reason that your wall cabinet would be in the wall is if your collisions button is turned off. Make sure collision is turned on from the bottom right hand side of the program. See attached image.
For more information, I would suggest to reach out to support so they may take a closer look at the design to see what could’ve happened. You can contact us by calling 1.866.697.2020.
