January 3, 2023 at 11:26 am
#418275
Hi Catherine,
If the program is crashing while adding the Items List to your Drawing Layout then its possible there may be an issue with the file or the program. To test this out, you can see if another design works or not. If it does work then there is something wrong with the file itself. If it doesn’t work, then the issue could be the program. If the issue is the program, I would suggest running maintenance and then test out the program once more. Click HERE to see how to run maintenance.
At any time you can also contact our support department for assistance with this issue. You can reach us by calling 1.866.697.2020 to have an agent assist.
