April 15, 2025 at 6:28 pm
#440680
Use the TAB key to achieve the “right click” to select nearby or above/below items.
Also, have you worked with moving an item label? If you right click “move label” on the PN2796’s in your picture you can move the label out away from the appliance (or whatever). The label itself is clickable to select the item it represents.
