Reply To: Printing out Perspective view Bigger
March 7, 2016 at 11:18 am #78850
Edith
Hi Paula,
A couple of things you can check include making sure the design is rotated to fit the paper.  If your render runs north/south and the page is set landscape it will squeeze it into the space and it will be smaller.
Make sure that there isn’t an item off to one side that is shrinking the render.  If there is a filler or unused cabinet off to one side the program will still try to render it and make it fit the page.
Zoom in to the render so that no white space shows around the picture. This will minimize the white space that the program tries to fit on to the page.
Finally, if the image shows fully in the print preview but prints out small it is likely an issue with the driver for your printer.  Check with the manufacturer and make sure you are running the latest driver for your printer and not just the generic windows driver for it.
Hope that helps.
