3" Snap
    • May 2, 2017 at 6:40 pm #129175
      Merrill Dencklau
      All of a sudden, everything I move will only move in 3″ increments. From items in floorplan to elevations and even a point on a surface. I have item snap turned off. I’ve tried turning snap to zero in preferences as well. Using shift to override. Nothing works. Am I missing something? Thank you!
    • May 3, 2017 at 9:38 am #129179
      Hey Merrill,
      in the lower right corner you have your 7 icons. Make sure the Area Snap is not selected. Its the icon that looks like a grid.
    • May 3, 2017 at 12:22 pm #129348
      Merrill Dencklau
      Yeah, that was the first thing I tried. Thanks.
    • May 5, 2017 at 4:28 pm #129708
      Danny Steiger
      Pilot Pro
      I had this – had to do a registry reset:
      Start – type “Maintenance tools” – enter or click
      select “2020 Design Registry Reset”
      This should do the trick, however you will lose any of your customizations to your work area (e.g. if you chose to disable ribbon mode it will be back to on by default, any other preferences will be reset to factory settings, and all toolbars will return to factory settings)
      As a side note, @Neil, this is one of the most frustrating things about updating, registry resetting, or anything that requires changing all the preferences back… Any chance that could somehow save your preferences?
    • May 5, 2017 at 4:32 pm #129709
      Hey Danny,
      Right now there is no way to save the settings but the ability to do so is something that is being looked into. If they ever give me any kind of timetable information I will pass it along.
    • May 7, 2017 at 8:40 pm #129776
      Danny/Neil/Merrill
      I wrote a little script that saves the registry settings to the desktop. If you ever have issues, you just double click the file on the desktop and it restores your settings. Obviously you run my script when everything is working perfectly.
      Script: https://www.dropbox.com/s/325jc3y10ymxskw/V112020RegistrySaver.cmd?dl=0
      Instruction Video: https://www.dropbox.com/s/w4it33f69d86dov/Registry%20Saver.webm?dl=0
      Works with V10 and V11
    • May 25, 2017 at 3:39 pm #131540
      Lin Hamilton
      Pilot Pro
      I turn my area snap off, but it keeps coming back on by itself.  Does it have to be turned off for each new design?  Each design session?
    • May 30, 2017 at 10:59 am #131958
      Hi Lin,
      No, that feature should be a toggle and it should be remembered from session to session. Since you mentioned it I have noticed it happening on my computer as well. Not frequently but every couple of days or so I notice its back on. We’ll look into it here and see if we can reproduce. If we can we’ll see what we can do to stop it from happening. 🙂
    • June 14, 2017 at 4:18 pm #134934
      Chris Blackman
      the registry save script has been an absolute Life saver for me.
      I have to reset the registry about once a week. Ok, maybe I don’t have to but when Design starts getting all funky resetting the registry helps a lot.
    • June 14, 2017 at 8:38 pm #135020
      Glad it helped Chris – donations gratefully received at your favourite charity!  😎
    • October 15, 2018 at 10:37 am #208567
      Ivan Radosavljevic
      where is the toggle to turn snap on and off? I can’t find it anywhere – and no, it’s not in the lower left of the screen…
    • October 15, 2018 at 10:51 am #208571
      Ivan Radosavljevic
      Not to worry – I found it! Right clicked on the orange bar (V11) and selected drawing control…
