Is there a way to change the Dimensions of Appliances from Cloud to fit the requirement of the design, some appliances can be changed with regards to depth and width but cant be changed with regards to height
If the appliance has a variable available that you can change you can do it but if there is no variable available it was not programmed into the shape and you cannot modify it.
